el mio....a ver que le ven los expertos!!!
Thursday,29,October,2015,17:09:33:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
Mileage: 580km-360mi Repair Order: 151029
Chassis Type: 5N (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 42 44 46 4C 4F 52 53 55
5F 61 62 6C 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CUVC) Labels: None
Part No SW: 04L 906 016 CL HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1841
Revision: 8AH20---
Coding: 01190032042401083000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TDI01104L906016CL 001004
ROD: EV_ECM20TDI01104L906016CL_VW36.rod
VCID: 75F9F69F85C1CF2A3CF6DF9-8020
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BN HW: 5N0 614 109 BN
Component: J104 C6 450M VD17 0021
Revision: --H07--- Serial number: 00000008970175
Coding: 0038203
VCID: 78E7FFAB92D3BEC227D0FE5-802C
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0375446574
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G.rod
VCID: 37653C97DF4D7D3AEE4AB51-8062
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 1K8 907 044 AB HW: 1K8 907 044 AB
Component: Climatronic H05 0304
Revision: 00001K03
Coding: 001000C003
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 6FF5C4F7E79DF5FAF63A1D1-803A
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 T HW: 5K0 937 086 T
Component: BCM PQ35 M 122 0183
Revision: BC122001
Coding: 60180A3B88250AC4408800C0340009644BD53F08676D81B0E4848700A041
VCID: 4599465F95A11F2A6CD62F9-8010
Subsystem 1 - Part No SW: 5N1 955 119 B HW: 5N1 955 119 B
Component: WWS316 300715 24 0664
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 200815 05 54 0403
Coding: 02304D
